'Python Scripting for ArcGIS Pro' data issue
1707
11-26-2020 12:27 PM
luckyphil78
The elevation data supplied with exercise 10 will not load onto a map as ArcGIS says it is an unsupported type.
On page two of the exercise document, it shows that the dataset has a band called band_1.  This does not show up in my catalog pane when I try and expand on the dataset.
DavidPike
MVP Notable Contributor
I've tried it and seems fine.  Could you provide a screenshot(s) and what version of Pro you're using?
You've also downloaded the data from here right? Python Scripting for ArcGIS Pro (Esri Press)
DavidPike
luckyphil78
Hi David,
Using 2.6.3.  Yes, have downloaded from that site.
DavidPike
I dont have Ele.asc, have you re-downloaded the file and unzipped it correctly?
luckyphil78
Ele.asc is some elevation data I downloaded for a different area so i could do the exercise.  It didnt come from the zip file.
All the other data from the zip file works.
