GIS Tutorial 1 for ArcGIS Pro: A Platform Workbook, first edition: tutorial data
956
01-15-2021 09:36 AM
RachelCanham
Hello, I am not able to download and install the gist1prodata.exe file on my work computer (admin restrictions). is there somewhere that I can download just the data (e.g. shapefiles) so that I can complete the exercises in the textbook?
Thanks!
Rachel
Craig_Carpenter
Hi Rachel,
The data for that book is only supplied as an executable and unfortunately sometimes that is blocked by administrator restrictions. I would suggest downloading and installing the executable file on another machine that you have administrator privileges for. The default location will be C:\EsriPress. Then you could use a portable drive to transfer the files to a different machine. I would suggest zipping them in the transfer process to make sure everything is moved. I hope that helps.
Craig
Craig_Carpenter
Hi Rachel,
Craig
