Cannot log in to "Sign in to Esri Tutorials"
1220
01-08-2025 12:24 PM
TimothySHare
How do I log in to ESRI Tutorials? When I try to click on some links in "Introduction to Human Geography Using ArcGIS Online" the resources flash on the screen for a second and then are replaced with the login box labeled "Sign in to Esri Tutorials". I use my ArcGIS Online account login, but it says my login or password is incorrect. Is there a special "ESRI Tutorials" organization that requires a special login?
Craig_Carpenter
We've updated several of these maps, so they can continue to be used along with the book. Shoot me a message if you find ones that need to be addressed.
BrendanNewell
@TimothySHare can you please include a link to the course you are referencing as I can not locate this.
To answer your second question you will use your ArcGIS Online login to access content located on the Esri Academy. However, you will have to ensure the admin of your ArcGIS Online Org has enabled Esri Access for your account
TimothySHare
Thanks for your response. Esri Access is already enabled. After exploring more, I've found that many of the links in the book work fine. Only a few cause the problem, which makes me think it is a problem on the data publisher's side.
Craig_Carpenter
