Launch Map Viewer and Map Extent
3193
03-12-2013 01:44 AM
Ick_HoiKim
I am using the default Map Viewer (Flex). When I click on "Add To Map", the initial extent of the Map Viewer is the global extent rather than the data extent. Actually, I can manually zoom to the data extent by extending "More..." and click on "Zoom to" on the data layer searched on the Geoportal.
But I want the Map Viewer (not search map) to zoom to the data extent automatically.
Please, let me know which file I should check.
Thank you for your advice in advance!
Rick
