Geoportal Login Fails on Connection to Postgresql
2351
02-07-2011 12:23 PM
TomGiles
I have a geoportal setup with postgresql, tomcat 6 using windows AD.
When I attempt to login to the geoportal, I get the error message:
"A valid userid was not auto-generated for remote user: cn=gptAdmin,ou=users,ou=gis,dc=gis,dc=local"
I am certain that I am connecting to the LDAP, and the database. The issue seems to be coming from postgres db access/config.
In my pg_hba.conf file I am currently not restricting any access (I am using 'host all all 0.0.0.0/0 trust').
If anyone has seen this error message or knows more about it I could use a push in the right direction! I couldn't find anything on the geoportal site or in the help files.
Many thanks,
Tom
DennisGeasan
Occasional Contributor II
Check the definition of the Geoportal roles in your gpt.xml file.  If the portal cannot find a user ID in one of the roles (AD Groups) it will complain.  The portal authenticates with AD to establish a users ability to edit metadata and/or manage a profile.  Can you see metadata in a search of your portal before you login?  If so then your connection problem is with AD.
Dennis Geasan
GIS Technologies
TomGiles
