CSW Client not showing up after install - 10.1
5133
10-12-2012 10:18 AM
RandyKreuziger
I've installed the CSW Client I downloaded off sourceforge.net.  The install went ok but I'm not seeing any "Geoportal" group under the Customize, Customize mood, Commands tab.  I even tried typing CSW in the "Show commands containing" in both ArcCatalog and ArcMap  but it's not showing up.  Any ideas?
BTW, I'm running ArcGIS 10.1 on a Windows 2008 R2 server.
DonaldBrown
I had the same problem after I ran setup.exe in the 'CSWClientsforArcGIS' folder.
To solve my problem, I ran setup.exe in the 'GeoportalPubishClient' folder.
The 'GeoPortal' option now shows up in 'commands' tab.
TrilliumLevine1
Donald's sollution does indeed get the Geoportal option to show up in the commands tab, but the CSW Client option is still not available.  Anyone else run into issues with this?
