SERVIVE TERRITORY IS ADJUSTABLE?
1998
05-31-2023 11:12 AM
RomuldKiobya
My client works in Tanzania, prove electrical service to entire the county.  I used  Tanzania country map to create service territory . After collect data at certain places we discovered that the resources like transformers, poles , and others were used with customers from neighbors countries who stay closer to Tanzania. is is it easy to adjust service territory  to include those data
by Anonymous User
Not applicable
Hi Romuld,
You cannot expand the extent of an existing Utility Network.
The easiest process is to export the Utility Network to an Asset Package.  In the Asset Package, expand or adjust the extent.  Create a brand new EGDB, stage a new Utility Network and apply the asset package.  Then republish your services.  If you use the same name or overwrite your services, this should not affect any downstream maps.
Tags (1)
by Anonymous User
Not applicable
Hi Romuld,
Tags (1)
JesseCloutier
Esri Community Manager
For reference and tracking: Post was by @JesGooch on 5/31/2023
Jesse Cloutier
Community Manager, Engagement & Content
RomuldKiobya
After export to asset package,..... and replace  Tanzania map with East Africa map as service territory. I suppose to append again all data   it means to start over again?
RobertKrisher
@RomuldKiobya when you export your asset package you can (and should!) choose to include the data from your database. Then after you've adjusted your service territory in the asset package you should apply the asset package to a new geodatabase.
