Hello, I'm having problems with the 'jimu-for-test' library when my components contains a <Checkbox> imported from the Jimu-ui library.
This is my component:
export class MyComponent extends React.PureComponent<{ }, { }> {
render() {
return (<div>
<Checkbox checked={true} onChange={() => { }} />
</div>)
And this is the unit test:
import { React } from 'jimu-core';
import { render } from 'jimu-for-test';
import { MockResizeObserver } from '../../../testing/mocks';
describe('Sortable List', () => {
MockResizeObserver();
it('renders checkbox', async () => {
const component = render(<MyComponent />)
expect(component.getByRole("checkbox")).toBeTruthy();
However this fails on line 8, when it tries to render the component:
C:\...\client>npm run sampletest
> exb-client@1.14.0 sampletest
> jest --runInBand sampletest.test
ts-jest[ts-jest-transformer] (WARN) Define `ts-jest` config under `globals` is deprecated. Please do
transform: {
<transform_regex>: ['ts-jest', { /* ts-jest config goes here in Jest */ }],
FAIL sample.test.tsx
● Sortable List › renders checkbox
TypeError: Cannot read properties of undefined (reading 'checkbox')
1382 | box-shadow: 0 0 0 1px ${a.focusColor};
1383 | } */
> 1384 | &.disabled {
1385 | &,
1386 | &.checked, &.indeterminate {
1387 | background: ${r.disabled.bg};
at eo (dist/jimu-ui/index.js:1384:111)
at dist/jimu-theme/index.js:46:85554
at qP (dist/jimu-core/index.js:46:744751)
at eD (dist/jimu-core/index.js:46:745060)
at dist/jimu-core/index.js:147:51225
at dist/jimu-core/index.js:46:746094
at renderWithHooks (node_modules/react-dom/cjs/react-dom.development.js:16305:18)
at updateForwardRef (node_modules/react-dom/cjs/react-dom.development.js:19226:20)
at beginWork (node_modules/react-dom/cjs/react-dom.development.js:21636:16)
at beginWork$1 (node_modules/react-dom/cjs/react-dom.development.js:27426:14)
at performUnitOfWork (node_modules/react-dom/cjs/react-dom.development.js:26560:12)
at workLoopSync (node_modules/react-dom/cjs/react-dom.development.js:26466:5)
at renderRootSync (node_modules/react-dom/cjs/react-dom.development.js:26434:7)
at recoverFromConcurrentError (node_modules/react-dom/cjs/react-dom.development.js:25850:20)
at performConcurrentWorkOnRoot (node_modules/react-dom/cjs/react-dom.development.js:25750:22)
at flushActQueue (node_modules/react/cjs/react.development.js:2667:24)
at act (node_modules/react/cjs/react.development.js:2582:11)
at node_modules/@testing-library/react/dist/act-compat.js:46:25
at renderRoot (node_modules/@testing-library/react/dist/pure.js:161:26)
at render (node_modules/@testing-library/react/dist/pure.js:247:10)
at render (jimu-for-test/lib/test-utils.tsx:19:17)
Any thoughts? I'm quite lost.
Thanks!
Alejandro
