Unable to complete Operation on multi-table joined service
3105
10-01-2015 07:28 AM
DavidWendelken
We're having a problem with querying a service that's based upon multiple joined tables.
The service sets up ok and if I query it with a where clause of "1 = 1" it returns the data it should.
But if I try to query against any of the fields, i.e., fieldname = 'joe' or fieldalias = 'joe'  I get an unable to complete operation error.
Any ideas about how to proceed?
Tags (1)
DavidWendelken
I just used sql server's sql profiler to see what queries are actually issued by the esri query screen against this service.  The hope was I could figure out what text string to pass it so that it could correctly filter on a field's value.
I'm guessing that this query issuing code was done back in ancient times when dbase II was brand spanking new and there were all kinds of technical limitations to work around.  Either that or someone was taking some controlled substances.
I'm going to try building a view in the database and point the service to that instead.  If that doesn't work (at all or fast enough), I'll just denormalize the data into a single table.
I'm no longer expecting an answer that shows how to make the query work.
(But I would love to be surprised.)
