Split and Get value with arcade
16947
38
06-11-2021 08:06 AM
KARIMLABIDI
On Arcgis Portal, I would like to represent my buses line with Arcade and HTML. I would like get the number of the line and put colors in relation to the numbers.
My value are like that on my stop feature : Line 1, Line 2, ..., Test 56.
My first problem is to get the number only. I can split the field but then I don't know how the get the value.
Is someone think it's possible or too complicated? With IIf maybe?
I know this blog but my problem is little more different. https://www.esri.com/arcgis-blog/products/arcgis-online/mapping/combining-arcade-and-html-for-a-real...
Thank you
JohannesLindner
Hi again!
Yeah, please post the code you use. The HTML and at least one of the Arcade expressions.
Have a great day!
Johannes
John_Shell
Hi Johannes,
Can you help me with an issue in my pop-up?
John
https://tacoma.maps.arcgis.com/apps/mapviewer/index.html?webmap=c80eda9c8e434844a8ddbe742fc11a9c
This is for my expression1 links. The text display is correct for the intersecting polygons; however I don't know to to show individual weblinks without it merging the links together in a webpage.
John_Shell
Hi Pedro, Did you ever find a solution for your weblinks merging together like car.bike?
I am having similar issues.
Thank you
John
JohannesLindner
Hey @John_Shell (and @PedroSoares1 , if you care),
this thread is messy enough, I'll post in the original question: Arcade Popups with multiple web links - Esri Community
Have a great day!
Johannes
PSGeo
Thanks, for the support. I just took days off, I cannot be a big support on this.
I agree with u, too messy.
Kind regards,
Pedro
John_Shell
I am having issues with multiple links from a single field. A one to many and I need each hyperlink to be on its' own line. In the test of arcade it looks fine but in the popup after clicking on the link it merges two or more links together.
Thank you,
John Shell
PedroSoares1
Hi, I am bit busy this week. but could you share the code you have done? meanwhile this is a sample of what i have. cheers
1 - the custom attribute Display such as:
<tr style="display:{expression/expr0}"> <td style="width:200px; text-align:left; background-color:#302f2f; padding:2px"><a href="https://....">Car</a> </td> </tr>
2 - the two expressions: bike and car (remember need to be two expressions) such as:
//show_Car
var arrName = Split(replace($feature. Vehicle, " ", ""),",")
for (var i in arrName) {
      if(arrName[i]=="car") {return "block"}
return "none"
John_Shell
Hi Pedro,
Here is my expression for the links:
// Write a script to return a value to show in the pop-up.
// For example, get the average of 4 fields:
// Average($feature.SalesQ1, $feature.SalesQ2, $feature.SalesQ3, $feature.SalesQ4)
var areas =FeatureSetByName($map,"Neighborhood Council Districts (Tacoma)");
var Onefifty = Buffer($Feature, -150, 'feet')
var countp = Intersects(areas,Onefifty);
var result = "";
for (var item in countp){
var id = item["URL"] + Textformatting.newline + Textformatting.newline;
result += id + '\n'
return (result)
Thank you,
John
PSGeo
How do u have your attribute display code?
John_Shell
In the arcade expression and then in the pop up editor in Map Viewer.
John
