So I have this VBScript in labeling that I'm trying to convert to Arcade but didn't get it solution.
2104
12-14-2023 12:41 AM
Rajeshmadhaiyan
Do you have any coveter tool if you have any please send me that,
Below mention the VB scripts code, Please someone can you help me that.
Dim result
If [Detect]= "N" and [Pre_Detect]= "N" then
result = [TextstringEdit] &vbnewline& [Post] &"<ITA>/"& [Pre_Post] &"</ITA>"
ElseIf [Detect]= "N" and [Pre_Detect]= "Y" then
result= [TextstringEdit] &vbnewline& [Post] &"<BOL><ITA>/"& [Pre_Post] &"</ITA></BOL>"
ElseIf [Detect]= "Y" and [Pre_Detect]= "N" then
result = [TextstringEdit] &vbnewline& "<BOL>"& [Post] &"</BOL>"&"<ITA>/"& [Pre_Post] &"</ITA>"
ElseIf [Detect]= "Y" and [Pre_Detect]= "Y" then
result = [TextstringEdit] &vbnewline& "<BOL>"& [Post] &"</BOL>"&"<BOL><ITA>/"& [Pre_Post] &"</ITA></BOL>"
Else result = "Error in result"
End If
__esri_field_calculator_splitter__
result
Rajesh M
[email protected]
3 Solutions
jcarlson
I don't know any automatic converters out there, but rewriting your conditions is simple enough.
Instead of "If condition then do something", you write "If(condition){do something}"
Text formatting in Arcade is easy as well. To build out a string, you can just separate your strings / string variables with "+" operators, and vbnewline can be replaced with textformatting.newline, <br>, or \n, depending on where the script is evaluating.
A direct translation would look like this:
var result
if ($feature.Detect == 'N' && $feature.Pre_Detect == 'N') {
  result = $feature.TextstringEdit + '\n' + $feature.Post + '<ITA>' + $feature.Pre_Post + '</ITA>'
} else if ($feature.Detect == 'N' && $feature.Pre_Detect == 'Y') {
  result = $feature.TextstringEdit + '\n' + $feature.Post + '<BOL><ITA>' + $feature.Pre_Post + '</ITA></BOL>'
} else if ($feature.Detect == 'Y' && $feature.Pre_Detect == 'N') {
  result = $feature.TextstringEdit + '\n<BOL>' + $feature.Post + '</BOL><ITA>' + $feature.Pre_Post + '</ITA>'
} else if ($feature.Detect == 'Y' && $feature.Pre_Detect == 'Y') {
  result = $feature.TextstringEdit + '\n<BOL>' + $feature.Post + '</BOL><BOL><ITA>' + $feature.Pre_Post + '</ITA></BOL>'
} else {
return result
But we can make some serious improvements to this in Arcade. For one, let's assign your attributes to variables. Instead of typing out "$feature.TextstringEdit" every time, we could have something shorter.
Second, we can use template literals for strings with variables piped in and do away with all of those + operators.
Here's what it looks like with those two things implemented. The code is taller, but not as wide, and a bit more readable.
var result
var detect = $feature.Detect
var predetect = $feature.Pre_Detect
var tse = $feature.TextstringEdit
var post = $feature.Post
var prepost = $feature.Pre_Post
if (detect == 'N' && predetect == 'N') {
  result = `${tse}\n${post}<ITA>${prepost}</ITA>`
} else if (detect == 'N' && predetect == 'Y') {
  result = `${tse}\n${post}<BOL><ITA>${prepost}</ITA></BOL>`
} else if (detect == 'Y' && predetect == 'N') {
  result = `${tse}\n<BOL>${post}</BOL><ITA>${prepost}</ITA>`
} else if (detect == 'Y' && predetect == 'Y') {
  result = `${tse}\n<BOL>${post}</BOL><BOL><ITA>${prepost}</ITA></BOL>`
} else {
return result
But we can go further! Since you're just checking if those two fields are "Y" or "N", we can actually do the check in the variable assignment, which makes our "detect" and "predetect" variables booleans. Using them in a condition is much more concise that way. "predetect == 'N'" becomes "!predetect".
Further, a long if/else block that is being used to set a single parameter can be written with a When function. Long if/else blocks are better suited to cases where you are literally doing different things based on the condition.
var detect = $feature.Detect == 'Y'
var predetect = $feature.Pre_Detect == 'Y'
return When(
  !detect && !predetect, `${tse}\n${post}<ITA>${prepost}</ITA>`,
  !detect && predetect,  `${tse}\n${post}<BOL><ITA>${prepost}</ITA></BOL>`,
  detect  && !predetect, `${tse}\n<BOL>${post}</BOL><ITA>${prepost}</ITA>`,
  detect  && predetect,  `${tse}\n<BOL>${post}</BOL><BOL><ITA>${prepost}</ITA></BOL>`,
  "Error in result"
And we can actually go one more step. Looking at what your expression is actually doing, it appears that when detect is 'Y', the "post" attribute is bold, and the same for pre_detect and "pre_post". Rather than doing an if/else or When series of conditions for each unique combination, we can do each of these separately, then combine them at the end.
var prepost = `<ITA>${$feature.Pre_Post}</ITA>`
var post_string = Iif(
  detect,
  `<BOL>${post}</BOL>`,
  post
var prepost_string = Iif(
  predetect,
  `<BOL>${prepost}</BOL>`,
  prepost
return `${tse}
${post_string} ${prepost_string}`
- Josh Carlson
Kendall County GIS
Rajeshmadhaiyan
Thank you so much! This is very helpful @Josh Carlson.
I will check it that code.
Rajeshmadhaiyan
Hello Josh Carlson,
I have checked the below code it's working good.
It's code come output like. but missing for "/".
 2345
I need to come to below output.
var result
} else {
return result
Rajesh M
jcarlson
var result
} else {
return result
var result
} else {
return result
return When(
  "Error in result"
  detect,
  post
  predetect,
  prepost
return `${tse}
- Josh Carlson
Kendall County GIS
Rajeshmadhaiyan
Rajeshmadhaiyan
Hello Josh Carlson,
 2345
var result
} else {
return result
Rajesh M
Rajeshmadhaiyan
Converting VBScript to Arcade
So I have this VBScript in labeling that I'm trying to convert to Arcade,
VBScribt expression: [TextStringEdit] &vbnewline&"<CLR black='100'>"& [Post]&"</CLR>"
Rajesh M
