Simple way to reproduce the behavior of '&' in a VBScript label expression, using Arcade label expression instead?
1743
8
05-30-2020 01:57 PM
ColeSutton11
My question is at the end of the post, but first I will give an example of the behavior I'm trying to replicate... When writing a label expression in VBScript, I sometimes take advantage of the difference between '+' and '&' when concatenating attributes and text. For example, lets say I'm labeling sewer pipes. I could write the following expression:
[LENGTH] & " ft. " & [DIAMETER] & "-inch " & [MATERIAL] & " @ " & [SLOPE] & "%"
And assuming the attributes are fully populated, the label might look like this:
50 ft. 12-inch PVC @ 2.5%
But sometimes we don't have all the information. If an attribute is missing (let's say the slope), the bits of text supporting it, "@" and "%", would still be hanging there:
50 ft. 12-inch PVC @ %
We likely don't want that to happen. By tying two or more elements together with '+' instead of '&', any element tied to a null value will be ignored. Consider the following modified example:
[LENGTH] + " ft. " & [DIAMETER] + "-inch " & [MATERIAL] & " @ " + [SLOPE] + "%"
Now if the slope attribute was null, the "@" and "%" would be left out like this:
50 ft. 12-inch PVC
If just the length was null:
12-inch PVC @ 2.5%
If the diameter and material were null:
50 ft. @ 2.5%
You see we have a fairly flexible expression. Finally, if you were to use only '+' operators, and no '&'...
[LENGTH] + " ft. " + [DIAMETER] + "-inch " + [MATERIAL] + " @ " + [SLOPE] + "%"
...Then whenever any attribute is missing, the entire label will be left out. The effect can be a useful visual cue. A pipe's label would be missing entirely until every attribute needed for the label had been populated.
Finally, my question...
In Arcade label expressions, it seems that '+' behaves the same way '&' does in VBScript. Is there a similar easy way to achieve the behavior I've described of the VBScript '+' using Arcade, without to having check for nulls using IsEmpty?
Thanks!!
JoshuaBixby
MVP Esteemed Contributor
VBScript's time has come and gone, assuming it ever came in the first place, but I loathe Arcade.  Even if you don't take issue with Esri creating a new, proprietary language, which I do take issue with, usability wasn't a design priority if JavaScript was the inspiration for syntax and structure.
The short answer to your question, no, there is no equivalent behavior in Arcade for what you are doing in VBScript.  That said, what you are doing with VBScript isn't even a feature of VBScript, it is an Esri VBScript implementation behavior that won't transfer to other applications.
Something along the lines of below should work for you and not be too convoluted in terms of structure:
var flds = [$feature.LENGTH, $feature.DIAMETER, $feature.MATERIAL, $feature.SLOPE]
var pref = ["", " ", " ", " @ "]
var suff = [" ft.", "-inch", "", "%"]
var lbl = ""
for(var k=0; k<Count(flds); k++) {
    if (IsEmpty(flds[k])) continue;
    lbl = lbl + pref[k] + flds[k] + suff[k];
return lbl;
DavidPike
MVP Notable Contributor
I think I've done it ok in python, I'm sure there's a better way though. I'm not sure how the locals() will go in arcade as not very familiar with the syntax, is it just 'var' infront of every variable?
length = 2.5
diameter = 1
#material =" WOOD"
slope = 25
if 'length' in locals():
    length = str(length) + " ft. "
else:
    length = ""
if 'diameter' in locals():
    diameter = str(diameter) + "-inch"
else:
    diameter = ""
if not 'material' in locals():
    material = ""
if 'slope' in locals():
    slope = " @" + str(slope) + "%"
else:
    slope = ""
return (length + diameter + material + slope)
DavidPike
actually
length = "LENGTH! etc. so can just be if length: instead of if 'length' in locals(): same for the rest.
JoshuaBixby
var lbl = ""
return lbl;
curtvprice
I could not agree more. "That @#$% circus language"
MichaelVolz
Thanks for the example, the best part of GeoNet.
ColeSutton11
Thanks for your reply and example Joshua! I knew (I think mainly from pro training vids) that VBScript is out and Arcade is in, but I'm too naive to feel ways about it, haha. Since you mention it, I guess it does kinda suck that they went and created a something proprietary. Now I'm wondering how worthwhile it is to work on updating my label expressions in Arcade in the first place. Perhaps I should try to use Python more instead.
JoeBorgione
No fan of arcade either, but won't concatenate() do the same thing as '&' in vb?
That should just about do it....
ColeSutton11
Forgive me Joe. The title of my post suggests I'm looking to do what '&' does in vb, but my question is actually asking about replicating the '+' behavior from vb, in contrast to '&'.
