Is it a good idea to run ArcPy in .Net App
566
01-24-2023 03:35 PM
AlexBykov
Hey guys,
I need to create an app to:
1. set arcGIS Server1 (no portal or webAdapter) to maintenance mode
2. publish MapServer, GeoCodingServer, NetworkAnalyst for routing to Server 1
I found that ArcGIS REST API will allow me to set Machine (Server1) to maintenance mode.
However, I don't think I can publish SD using REST API. I was thinking to make .NET App to build GUI and access REST API.
As the result, I need to use ArcPy.
However, when I search for "execute arcPy from .NET" I get answers to use ArcGIS SDK for .NET. I couldn't find the way to publish SD using SDK in the documentation.
Please direct me.
Thank you very much!
Alex.
