Invalid Where clause - Left function - Expression Builder - Arcade - Attribute Rule
4813
17
08-07-2024 07:38 AM
hw_mwf
Trying to create an attribute rule (immediate calculation rule) on a feature class within an Enterprise Geodatabase in Oracle (.sde) within ArcGIS Pro 2.9.5. I want to filter to improve performance. Specifically, selecting only records when the first five characters of the UNITID text field equal the WINDEX text field. I am starting with the following two lines of Arcade code in the Expression Builder and when I click the green Verify check mark, its says 'Expression is valid'.
var cur_unitid = Filter(FeatureSetByName($datastore, "WSL", ['UNITID'], false), 'Left(UNITID, 5) == $feature.WINDEX');
var cur_unitid_desc = OrderBy(cur_unitid, 'UNITID DESC');
However, when I add the following third line of code and click the green Verify check mark, it says 'Invalid expression. Error on line 3. Invalid where clause (Left(UNITID, 5) == $feature.WINDEX)'.
var cur_unitid_max = first(cur_unitid_desc);
Can the Left function be used on a feature class field name and/or is there an error in how I am using it?
hw_mwf
Agreed. The code works when the feature class is in a .gdb but not in a .sde. Specifically, the First function fails with a 'General evaluation error'. You did solve my initial problem (use a Substring function instead of Left), so I'll 'Accept as Solution' and repost this additional issue if I cannot figure it out. Thanks!
KenBuja
MVP Esteemed Contributor
Your sql expression is invalid, since it doesn't understand Arcade syntax (including variables such as $feature). You can only use SQL92 syntax. An expression like this should work
var value = $feature.WINDEX;
var cur_unitid = Filter(FeatureSetByName($datastore, "WSL", ['UNITID'], false), "Substring(UNITID, 1, 5) = @value");
hw_mwf
Thanks for the reply. The first 3 lines of your code yield 'Expression is valid', however the 4th line yields the error 'Invalid expression. Error on line 4. General evaluation error'.
KenBuja
Have you tried completing the rule, adding in what you want to return?
hw_mwf
I added the below as the 5th line, and the error remains (Error on line 4. General evaluation error).
return cur_unitid_max.UNITID;
KenBuja
What happens with this code? I know it's not giving the maximum record, but it's just testing out the filtered result.
//var cur_unitid_desc = OrderBy(cur_unitid, 'UNITID DESC');
var cur_unitid_max = First(cur_unitid);
hw_mwf
Still the same error.
KenBuja
Let's check whether you're getting anything back from the Filter
return Count(cur_unitid);
hw_mwf
This is now the error 'Invalid expression. Error on line 3. Failed to query statistics.
KenBuja
The testing I've done in the Playground using the example public portal item has worked correctly.
Are you sure you have the correct information for the FeatureSetByName function? What happens with this code?
var cur_unitid = FeatureSetByName($datastore, "WSL", ['UNITID'], false);
