In javascript, how do you call a function?
891
04-29-2023 04:56 AM
hectorsalamanca
I've written a constructor function that registers an event handler:
function MyConstructor(data, transport) {
this.data = data;
transport.on('data', function () {
alert(this.data);
// Mock transport object
var transport = {
on: function(event, callback) {
setTimeout(callback, 1200);
// called as
var obj = new MyConstructor('foo', transport);
However, I am unable to access the created object's data property within the callback. It appears that this does not refer to the object that was created, but to another.
I also attempted to use an object method rather than an anonymous function:
this.data = data;
transport.on('data', this.alert);
MyConstructor.prototype.alert = function() {
alert(this.name);
However, it has the same issues.
How do I get to the right object?
KenBuja
MVP Esteemed Contributor
When JS used Dojo (before 4.18 and 3.x), using lang.hitch was the proper way to make sure that "this" retains the proper context.
In ES6, arrow function were introduced where the "this" scope is better preserved.
