How to delete the vertex in arcmap using vb.net?
2091
02-19-2016 04:38 AM
karthikm
Dear all,
         I am using arcmap 9.3 and vb.net i need to delete the vertex pragmatically. i have the feature and index of delete vertex but i dont know how to delete the vertex any one give me the sample code for delete vertex. i am using following code its not working.
  Function deletevertex(ByVal index As Integer, ByVal pointCollection As IPointCollection)
        Dim editorUID As UID
        editorUID = New UID
        editorUID.Value = "esriEditor.Editor"
        Dim editor As IEditor
        editor = (papp.FindExtensionByCLSID(editorUID))
        Dim editSketch As IEditSketch
        If editor Is Nothing Then
            Exit Function
        End If
        editSketch = CType(editor, IEditSketch)
        If index = -1 Then
        End If
        Dim sketchOperation As ISketchOperation
        sketchOperation = New SketchOperation
        sketchOperation.MenuString_2 = "Delete Vertex"
        sketchOperation.Start(editor)
        pointCollection = editSketch.Geometry
        pointCollection.RemovePoints(index, 1)
        editSketch.RefreshSketch()
        sketchOperation.Finish(editSketch.Geometry.Envelope)
    End Function
above code show the error of
"the index either too small or too large".
Note:
If i am select the Feature using "modifying Feature" that time vertex deleted successfully. if i am select the vertex using "new feature creation " that time only the index either too large or too small error showing.
