How to create a "Geocode (stored)" key?
1028
04-01-2026 01:29 PM
AlexanderAvtanski
I'm trying to use the `geocodeAddresses` API from a Python application. To the best of my understanding, this requires a "Geocode (stored)" API key.
When creating the key in the Developer credentials panel I see only the "Geocode (not stored)" option. How can I create a key with "Geocode (stored)" enabled?
I've been trying to figure this out for several hours now, so any help is welcome.
John-Foster
It may also depend on your account subscription type. If you are using ArcGIS Location Platform then you will need to enable Pay as you Go because geocode (stored) does not have a free tier. If you are using an ArcGIS Online subscription then it may be possible your admin set your account geocoding service or credit budget and you need to check with your admin.
--jf
Noah-Sager
You should be able to store the results of a geocode operation using the Geocoding privilege. I think we used to have a "stored" and a "not stored" option there, but it looks updated now. Do you specifically see "not stored", or do you see what I see in the attached screenshot?
AlexanderAvtanski
I see this - the "Geocoding" and "Geocode (not stored)" toggles move in sync - when I change one, the other changes the same way.
The documentation talks about "Geocode (stored)" - and shows a screenshot similar to the one above but with two toggles - one for stored and another for not stored...
John-Foster
--jf
