I am using arcpy for 10.2 and am able to set the initial extent of the map using the dataframe's extent property. This is the initial extent that the map comes up at when the MXD is loaded.
How do I set the full extent programmatically using arcpy?
This article describes how to do it in ArcGIS Desktop 10.2: ArcGIS Help (10.2, 10.2.1, and 10.2.2)
Also, the full extent shows up right next to the initial extent in ArcGIS Server when an mxd is published as a service. It feels like the setting is so close yet I have spent far too much time trying to decipher ESRI help articles to figure this out.
To be clear again:
Initial Extent: initial zoomed area when an mxd is opened up and a map documents dataframes extent value:
Example:
df = arcpy.mapping.ListDataFrames(mxd)[0]
newExtent = df.extent
Full Extent: area that is zoomed to by clicking the Full Extent(globe icon) button in ArcGIS Desktop 10.
Thanks for any help.
Solved! Go to Solution.
If I am not mistaken, Neil Ericksonis looking for a way to set a custom full extent in his data frame (for use in the Full Extent button). This is a property held by the data frame that doesn't change as you pan and zoom. This setting cannot be modified in Python. It is only able to be set through the GUI or ArcObjects.
The following python code will achieve what you want. It cycles through all the layers getting their extents and placing them in a temporary featureclass which you can then get the extent of and zoom to.
import arcpy
# Stop temporary layer being loaded into map
arcpy.env.addOutputsToMap=False
# Create a list of layers in map document
mapdoc = arcpy.mapping.MapDocument("CURRENT")
list =arcpy.mapping.ListLayers(mapdoc)
# A list of extents
extentList = []
# Cycle through layers grabbing extents, converting them into
# polygons and adding them to extentList
for layer in list:
if not layer.isGroupLayer:
desc = arcpy.Describe(layer.dataSource)
ext = desc.extent
array = arcpy.Array([ext.upperLeft,ext.upperRight,ext.lowerRight,ext.lowerLeft])
extentList.append(arcpy.Polygon(array))
# Create a temporary FeatureClass from the polygons
arcpy.CopyFeatures_management(extentList,r"in_memory\temp")
# Get extent of this temporary layer and zoom to its extent
desc = arcpy.Describe(r"in_memory\temp")
ext = desc.extent
mapdoc.activeDataFrame.extent = ext
# Clean up
arcpy.Delete_management(r"in_memory\temp")
del ext, desc, list, array, extentList, mapdoc
Hi Duncan,
Thanks for the reply. This script looks like it only sets the initial extent and not the full extent. Great code though.
To be clear, the 'intial extent' of a map document is the dataframes extent property which I am aware of how to use. I need the elusive 'full extent'.
The full extent is the extent of all the layers. If Duncan's code determines the minima and maxima of the associated layers, then that is the full extent. There is no otherway to obtain said information within arcpy or arcpy.mapping other than to cycle through the data and determine it iteratively
Thanks for the information, even if it's a bummer for me
I guess i'll have to work around it. Thanks. Could you put this in as an idea for future versions of arcpy?
Thanks
Here is the site where you can do that Esri Arcgis Ideas | Ideas Submission Portal
Based on this threat thread you can now use the tool Modify full extent mxd using ArcGIS for Desktop 10.3.
Enjoy,
Fred
Frédéric PRALLY I am assuming you meant thread and not threat We wouldn't want anyone getting ideas on how to initiate or expedite enhancement requests
