Setting the Custom extent of the Data Frame
3916
05-14-2013 12:56 AM
mdonnelly
I am wondering if it is possible to set the custom extent of a map document's data frame using ArcObjects 10.1?
I wish to take an existing map document, modify the custom extent of the data frame and then save it. Much the same way as you would do in ArcMap when editing the data frame properties (see image).
[ATTACH=CONFIG]24276[/ATTACH]
Any help would be appreciated.
Regards,
Mark
Regards,
Mark
mdonnelly
Thanks for the feedback.
In the end it was a closely related call I was after:
            m_AOLicenseInitializer.InitializeApplication(new esriLicenseProductCode[] { esriLicenseProductCode.esriLicenseProductCodeAdvanced }, new esriLicenseExtensionCode[] { });
            //ESRI License Initializer generated code.
            String path = args[1];              //Path to map document
            float xMin = float.Parse(args[2]);  //New extent xmin
            float yMin = float.Parse(args[3]);  //New extent ymin
            float xMax = float.Parse(args[4]);  //New extent xmax
            float yMax = float.Parse(args[5]);  //New extent ymax
            IMapDocument mapDoc = new MapDocument();
            if (mapDoc.get_IsMapDocument(path))
                mapDoc.Open(path, null);
                IMap map;
                for (int i = 0; i <= mapDoc.MapCount - 1; i++)
                    map = mapDoc.get_Map(i);
                    IMap currMap = map;
                    IEnvelope env = new EnvelopeClass();
                    IPoint llpoint = new PointClass();
                    llpoint.X = xMin;
                    llpoint.Y = yMin;
                    env.LowerLeft = llpoint;
                    IPoint trpoint = new PointClass();
                    trpoint.X = xMax;
                    trpoint.Y = yMax;
                    env.UpperRight = trpoint;
                    IClone sClone = currMap.SpatialReference as IClone; //Assuming the map document has the correct spatial reference.
                    ISpatialReference newSR = sClone.Clone() as ISpatialReference;
                    env.SpatialReference = newSR;
                    currMap.AreaOfInterest = env;
                mapDoc.Save();
            //Do not make any call to ArcObjects after ShutDownApplication()
            m_AOLicenseInitializer.ShutdownApplication();
Regards,
Mark
DuncanHornby
MVP Notable Contributor
Mark,
You manipulate the extent throught the IActiveView interface.
Duncan
mdonnelly
                IMap map;
                    IMap currMap = map;
                    llpoint.X = xMin;
                    llpoint.Y = yMin;
                    trpoint.X = xMax;
                    trpoint.Y = yMax;
                mapDoc.Save();
Regards,
Mark
