Hi, i'm developing an web app that use the Arcgis geocoder API and I discover there are some addresses with typos. For example, in Argentina, "Comodoro Py", sometimes is labeled "Comorodo Py" (this is, in all cases, a typo). I want to report this issue, or correct it, if it's possible.
Thank you in advance.
Hi, you can provide feedback by following these instructions:
https://support.esri.com/en/technical-article/000011831
Thank you!
Thank you!
