FeatureSetByRelationshipName Arcade function
4928
05-31-2021 01:23 AM
IhabHassan
Hi All,
I hosted the attached sample data on AGOL. I am trying to run the following arcade expression while configuring popup for the "Permits" layer.
var fs = FeatureSetByRelationshipName($feature, 'Permits_RelatedTbl_1', ['*'], false);
return fs;
However, I run into an error while testing the expression.
Execution Error:An error occurred.
There is a relationship as defined in the layer
"relationships" : [
      "id" : 0,
      "name" : "Permits_RelatedTbl_1",
      "relatedTableId" : 1,
      "cardinality" : "esriRelCardinalityOneToMany",
      "role" : "esriRelRoleOrigin",
      "keyField" : "globalid",
      "composite" : false
Any ideas ?
Regards
Ihab
Tags (3)
DavidPike
MVP Notable Contributor
I'd guess it's failing to return a featureSet into a popup Solved: How to use the FeatureSetByRelationshipName Arcade... - Esri Community
IhabHassan
it fails while testing the expression
Regards
Ihab
IhabHassan
I am not sure what is wrong with the arcade line or the sample, although it seems pretty straight forward to me, the function needs the relationship class name to retrieve the feature set, and I am providing the relationship name as it is defined in the service JSON description.
Any reason why this line would fail ? I tried this in both map viewers classis/new.
Regards
Ihab
PierreloupDucroix
MVP Regular Contributor
I have a similar issue, where I provide the name of the relationship as found in the service description, and the featuresetbyrelationshipname returns nothing...
Did you find an answer ?
CEO of MAGIS
