FeatureSetById not working as expected
3318
7
08-11-2020 05:52 AM
leonoestergaard
Hi
I got a FeatureServer with 1 layer and 1 table.
Im trying to create a popup on a webmap, the popup should display some data from the table, but the result is not as i expected. To figure out the issue, im using the following code
var all =FeatureSetById($map, "TrafoContainer_5842")
console("countAll: "+count(all))
console("TypeAll: "+TypeOf(all))
var tt = top(all,10)
console("TypeTT: "+TypeOf(tt))
console("countTT: "+count(tt))
var fst = First(all)
console("TypeFirst: "+TypeOf(fst))
return
In the console the following is printed
countAll: 15633 <---- This matches the number of features in the table
TypeAll: FeatureSet <---- Looking good
TypeTT: FeatureSet <---- Still happy
countTT: 0 <-----Oh no  I would have expected 10
TypeFirst: <------
Any ideas on what is wrong?
Tags (1)
XanderBakker
Esri Esteemed Contributor
Hi leon oestergaard ,
There is something strange going on in your case. I just used your code in the playground (ArcGIS Arcade | ArcGIS for Developers ) using one of the available layers and it works just fine:
leonoestergaard
Hi Xander Bakker
Thank you for your reply.
Can you confirm that "Parcels_And_buildings_3838" is a table?
The feature service I'm using consists of a layer and a table. If I query the layer using the same arcade script it works fine.
XanderBakker
Thanks for clarifying. The layer I used is not a table. I will test against a table and post back the result.
XanderBakker
Hi [email protected] ,
Just did a test on a table and it still works.
Is the data a hosted feature layer and table in ArcGIS Online? If so, could you share this data with me? You can create a group, share the data inside that group and invite me using my AGOL account "xbakker.spx".
leonoestergaard
Hi Xander Bakker
Its on our entreprise installation. Ive just tried a table from another service, and it works perfect. Guess we will have look at the table for that specific service. Thank you for the help
XanderBakker
It makes sense that it might be data-related. Please post back if you find a reason.
leonoestergaard
Hi Xander Bakker
We tried to removed all attributes from the table except objectid and globalid, the it worked, after re-adding the attributes it stil works. So the service might have been in some undefineable state
