Export to SHP with WhereClause
4422
10-17-2015 02:43 AM
SigurdurGear
Hi
I use this code to export to SHP but if the WhereClause  is null it still make empty SHP file
How can I stop the export if pQFilter.WhereClause is notthing
       Dim pDoc As IMxDocument
        Dim pMap As IMap
        Dim pFLayer As IFeatureLayer
        Dim pFc As IFeatureClass
        Dim pINFeatureClassName As IFeatureClassName
        Dim pDataset As IDataset
        Dim pInDsName As IDatasetName
        Dim pFSel As IFeatureSelection
        Dim pSelSet As ISelectionSet
        Dim pFeatureClassName As IFeatureClassName
        Dim pOutDatasetName As IDatasetName
        Dim pWorkspaceName As IWorkspaceName
        Dim pExportOp As ESRI.ArcGIS.GeoDatabaseUI.IExportOperation
        pDoc = My.ArcMap.Document
        pMap = pDoc.FocusMap
        pFLayer = pMap.Layer(ep_layer)
        pFc = pFLayer.FeatureClass
        pDataset = pFc
        pINFeatureClassName = pDataset.FullName
        pInDsName = pINFeatureClassName
        Dim pQFilter As IQueryFilter
        pQFilter = New QueryFilter
        pQFilter.WhereClause = "TYPE '" & ep_query & "'"
        pFSel = pFLayer
        pSelSet = pFSel.SelectionSet
        If pSelSet.Count = 0 Then
            Exit Sub
        End If
        If pFc.FeatureCount(pQFilter) <= 1 Then
            Exit Sub
        ElseIf pFc.FeatureCount(pQFilter) >= 1 Then
            pFeatureClassName = New FeatureClassName
            pOutDatasetName = pFeatureClassName
            pOutDatasetName.Name = ep_name
            pWorkspaceName = New WorkspaceName
            pWorkspaceName.PathName = path.txt
            pWorkspaceName.WorkspaceFactoryProgID = esriCore.shapefileworkspacefactory.1"
            pOutDatasetName.WorkspaceName = pWorkspaceName
            pFeatureClassName.FeatureType = ESRI.ArcGIS.Geodatabase.esriFeatureType.esriFTSimple
            pFeatureClassName.ShapeType = ESRI.ArcGIS.Geometry.esriGeometryType.esriGeometryAny
            pFeatureClassName.ShapeFieldName = "Shape"
            pExportOp = New ESRI.ArcGIS.GeoDatabaseUI.ExportOperation
            pExportOp.ExportFeatureClass(pInDsName, pQFilter, pSelSet, Nothing, pOutDatasetName, 0)
        Else
            Exit Sub
        End If
JoshuaBixby
MVP Esteemed Contributor
It appears you have an issue where you are never applying your non-spatial filter to your spatial selection or your spatial filter to your non-spatial selection until the ExportFeatureClass call at the very end of your script, hence the empty shape file.  I can't verify my hunch right now because I don't have VBA Compatibility installed.
As an aside, please use code formatting/syntax highlighting as described in Posting Code blocks in the new GeoNet​.  It is much easier for community member to comment when the code has line numbers.
After this line:
Try adding and changing the following to see if it makes any difference:
pSelSet1 = pSelSet.Select(pQFilter)
If pSelSet1.Count = 0 Then
    Exit Sub
End If
DanPatterson_Retired
You might want to specify which... of numerous .... places in Developers you wish this to move this..  Your tage should include things like the development language, the development environment etc.  This will facilitate getting an answer  check the (24) subspaces or at least one of the three main branches here....
JoshuaBixby
Can you elaborate on "the WhereClause  is null?"  A SQL WHERE clause can be absent/present or defined/undefined, but I would argue the clause itself cannot be NULL.  A SQL WHERE clause can contain search conditions that check for NULL conditions, but that is different than saying the clause itself is NULL.
You ask, "How can I stop the export if pQFilter.WhereClause is nothing?"  Is that question meant to imply that the line in the script, pQFilter.WhereClause = ..., doesn't exist sometimes or does it mean that ep_query isn't always defined or is an empty string?  My guess is that your issue is with ep_query, so it would be helpful if you could elaborate on what data type it is, where it is getting defined, and how it is getting defined.
SigurdurGear
do this help
When I export
1. "Draw a Graphic" to mark the area I want to export
2. go to Selection and select By Graphich
if 31 are inside the area I select it export 31 so that is ok
but if 32 and 33 are not inside the area it still export empty file for 32 and 33
ep_query is newer empty string
Arcmap
Field Details, Data TYPE is Long
   Export_with_query("1", "box1", "31")
   Export_with_query("1", "box2", "32")
   Export_with_query("1", "box3", "33")
       Public Sub Export_with_query(ByVal ep_layer, ByVal ep_name, ByVal ep_query)
        Dim pMap As IMap
        pDataset = pFc
        pQFilter.WhereClause = "BOXTYPE =  '" & ep_query & "'"
        pFSel = pFLayer
            Exit Sub
        End If
        Exit Sub
            pWorkspaceName.PathName = path.Text
            pWorkspaceName.WorkspaceFactoryProgID = "esriCore.shapefileworkspacefactory.1"
        Else
            Exit Sub
        End If
    End Sub
JoshuaBixby
After this line:
    Exit Sub
End If
SigurdurGear
Thanks Joshua this works
thanks for the help
