decode arcade
1551
01-15-2018 08:44 PM
RaviYernena1
How do i decode a field value into a different text. I have field value "High" but would like to configure the popup as "High Flood Risk Area" etc.
KenBuja
MVP Esteemed Contributor
If you follow the steps to configure your popup from the Help, when you get to the part where you configure the Arcade expression, you'll type in a expression like
if ($feature.yourfield == 'High') {
    return 'High Flood Risk Area'
KenBuja
RaviYernena1
Thanks Ken for you help. I have ended up using Decode function.
