Data Expression Date Formatting Dashboard Arcade
4432
08-31-2023 07:32 AM
BugPie
I have a Data Expression in a Dashboard that is used to create a table. Works great, was built by someone else.
I have one change I need to make but have been unable to get the syntax correct. I'm trying to get the table to return the date as a date only, no time.
The bottom half of the code is attached here. I left out the variables and portal item stuff. How do I get Date only in the return?
jcarlson
That part of the code isn't the issue. A date field is always going to include time, regardless of whether a time is specified when the data is created. To change how it displays, you'll need to use Advanced Formatting, then use something like Text($datapoint['Due_Date'], 'MMM DD, YYYY') to get an output like Aug 31, 2023.
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
BugPie
Oh for goodness sake, I'm so disappointed in myself!
OK, this makes so much more sense on why I could figure out how to use the code block to format the return. It's formatting!! That did the trick and I am eternally grateful for your help... again.
lannguyentl
Hi there, I'm quite interested in your conversation with other regarding the Text() function in Advanced formatting for List. Could you please share how you play with the return? I cannot find the way. Thank you very much!
