Creating links to documents using hyperlinked URL
1168
09-05-2017 09:58 AM
DaveKirkley
I'm hoping to create a link to a .pdf document from using a Prefix/FIELD/FIELD.pdf
Based on file:///G:/GIS/BV_Water/PDF_WS_CARDS/ABBOTT%20ST/6%20ABBOTT%20ST.pdf
which will on our internal server...
JakeSkinner
Esri Esteemed Contributor
SarojThapa1
Dave,
In the Field Calculator, choose Python and use a syntax very similar to the following:
"<a href=" 'domainURL'+""+ !FIELD1!+""+!FIELD2!+" "+'target="_blank" '  ">PDF</a>"
Hopefully this works for you. Try not to mismatch single quotations with double quotations.
