Convert JSON to GeoDataFrame and append both geometry and filename
1858
02-03-2022 01:54 AM
TamnaSidhart
I am currently running an experiment on automating a task by merging information from various files types and doing a number of operation to achieve this.
Currently, I am reading a a list of GeoJSONs and trying to build a GeoDataFrame that contains both the geometry and the filename.
Example of file name structure in folder is: event1.json
The desired geodataframe should look like this:
    index     geometry                      event_name
    0         LINESTRING1(coordinates...)   event1
    1         LINESTRING2(coordinates...)   event2
    2         LINESTRING3(coordinates...)   event3
I am able to read the JSONs and create the geometries, but I am not able to assign the matching filename.
     import os, geopandas as gpd
     event_tracks = gpd.GeoDataFrame(columns=['geometry', 'eventname'])
     directory = os.getcwd()
     for dir_root, dir_dir, js_file  in os.walk(directory):
       for f in js_file:
         if f.endswith(".json"):
         fname = os.path.basename(f)
         fname, fext = fname.split('.')
         print (fname)
         print ('Reading Track Path JSON ' + f)
         with open(f, 'r') as path_f:
           event_tracks = gpd.read_file(path_f).append(event_tracks)
The code above works for geometries and generates a geodataframe with valid geometries. However, I cannot assign the event name into the column. So far, I've tried to:
  • Create list of names and append list elements
  • Reindex and concatenate two different dataframes
However, it either returns a NaN-filled column or an error such as: TypeError: cannot concatenate object of type '<class 'list'>'; only Series and DataFrame objs are valid.
Is there any workaround to do this?
