I'm trying to write a script in my online notebook to create a buffer around my point data based on the values I have in a field. I have written the following script (its abit messy because I download it as a .md file so I could copy and paste it into this window)
TypeError Traceback (most recent call last) /tmp/ipykernel_703/2622654452.py in <cell line: 0>() 6 7 # Convert the result to a FeatureSet ----> 8 buffered_featureset = FeatureSet.from_dict(result) 9 10 # Iterate through the features and print their geometries /opt/conda/lib/python3.11/site-packages/arcgis/features/feature.py in from_dict(featureset_dict) 1133 """ 1134 features = [] -> 1135 if "fields" in featureset_dict: 1136 fields = featureset_dict["fields"] 1137 else: TypeError: argument of type 'FeatureCollection' is not iterable
Hi Toby,
The create_buffers task will return a FeatureCollection object (when no output_name is supplied). You can use the query method to iterate through each of the features returned in the response.
result = features.use_proximity.create_buffers(input_layer=layer, distances=[tpr_value], units="Meters", dissolve_type="Dissolve")
for feature in result.query():
print(feature.geometry)
Let us know if this helps or if you have any questions.
That worked great thank you. The next thing I am trying to do is to convert this buffer into a polygon and add it as a new feature to another feature layer I have. I have tried the following code:
target_layer_url = "https://services.arcgis.com/your_service_id/arcgis/rest/services/your_layer_name/FeatureServer/0" target_layer = FeatureLayer(target_layer_url)
new_features = []
# Iterate through the features in the result and add them to the target layer
buffer_geometry = feature.geometry
buffer_feature = Feature(geometry=buffer_geometry)
new_features.append(buffer_feature)
# Add all the new buffer features to the target layer at once
response = target_layer.edit_features(adds=new_features)
# Check if the operation was successful
if 'addResults' in response and all(result['success'] for result in response['addResults']):
print("All buffer polygons successfully added to the feature layer.")
else:
print("Failed to add some or all buffer polygons to the feature layer.")
But I keep getting this returned:
TypeError Traceback (most recent call last) /tmp/ipykernel_338/3308212656.py in <cell line: 0>() 1 for feature in result.query(): 2 buffer_geometry = feature.geometry ----> 3 buffer_feature = feature(geometry=buffer_geometry) 4 new_features.append(buffer_feature) 5 TypeError: 'Feature' object is not callable
As you can probably tell, I don't have alot of experience in coding. any help would be greatly appreciated
From the error message, it looks like you just need to add an uppercase F to feature(geometry=buffer_geometry)? Other than that it looks good and should run...
Thank you Mark, the buffers have now been created and loaded into my feature layer however all the polygons have been created as a single item instead of one item for each tree. My code is below. I tried to add a filter but that hasn't seem to work. I'm also wanting to pass the attribute data from my point layer to the new polygon layer if you are able to assist with this also?
from arcgis.gis import GIS
gis = GIS("home")
from arcgis.features import FeatureLayer
feature_layer_url = "https://services-ap1.arcgis.com/fmr3nGZRGUm3hVAY/arcgis/rest/services/Development_site_application/F..."
layer = FeatureLayer(feature_layer_url)
tree_id_to_process = 5
features = layer.query(where=f"tree_ID = {tree_id_to_process}", return_geometry=True)
print (features)
if not features:
print(f"No tree found with tree_ID = {tree_id_to_process}")
else:
# Assuming only one tree point should be returned, handle accordingly
feature = features.features[0] # Get the first (and hopefully only) feature
tpr_value = feature.attributes['tpr']
from arcgis import features
from arcgis.features import FeatureSet
result = features.use_proximity.create_buffers(input_layer=layer, distances=[tpr_value], units="Meters", dissolve_type="None")
# Define your target layer
target_layer_url = "https://services-ap1.arcgis.com/fmr3nGZRGUm3hVAY/arcgis/rest/services/Development_site_application/F..."
new_features = []
response = target_layer.edit_features(adds=new_features) # Corrected method name to `edit_features`
else:
