Arcgis Pro publishing broken geoprocessing services
2055
06-21-2020 07:32 AM
teofilosalgado
Hi all!
Recently I started moving my workflow from ArcMap to ArcGIS Pro but I am having some trouble publishing geoprocessing services with constant values as parameters.
I executed my tool normally, using features from my registered PostGIS database as parameters for inputTable.
Post image
Then I tried to publish it like so:
Post imagePost image
Post image
As I highlighted here, inputTable is a constant value, just like I used to set in ArcMap.
Then, after everything published, whenever I try to run this tool from my ArcGIS Server I got this error:
Post image
Looks like it isn't referencing to my database. And even when I choose to copy data to the server, providing shapefiles as constant inputs, I get the same error.
Have any of you guys faced this same error before? What should I do?
Any help will be very appreciated!
DavidPike
MVP Notable Contributor
Are is your data registered to the server as the Z:\ Drive? And do you have your connection for the SDE registered in the datastore?
teofilosalgado
Yep, although in this tool in specific I am not using registered data, instead I am using a registered database:
(Translation notes: Nome = Name, Tipo = Type)
When I publish from ArcMap all my references to registered data/databases work fine. Looks like I am doing something wrong with ArcPro, missing some specific setting I guess.
DavidPike
I'm not too sure of the constant parameter, can you not just have this as an input table parameter with the default set as that table, with a network path to the table?
teofilosalgado
Unfortunately no, I am not able to change de "Constant value" path, it's disabled and pointing to my local .sde exclusively. I tried to change it to a local shapefile and allow "Copy all data" like so:
and, even though, I get the same error as before 😕
