ArcGIS 11.1: How to migrate existing ArcObjects 10.8.1 Java based applications (not using GUI or Map)?
1190
10-08-2023 01:21 AM
Ranga_Tolapi
We currently have ArcObjects 10.8.1 Java based applications (not using GUI or Map). Understand from here that, Starting with ArcGIS Enterprise 11.0, the ArcMap runtime and, therefore, ArcObjects SDK are no longer supported.
Now, how to migrate the existing ArcObjects Java based applications on to ArcGIS 11.1 environment (OR) develop similar applications in ArcGIS 11.1 using Java.
Primarily, would like to achieve the below in ArcGIS 11.1 using Java (no need of GUI or Map):
  1. Connect to File based (.shp, .gdb), or Enterprise Geodatabases
    • to read/write features/rows.
    • to add/remove fields.
    • to calculate fields.
    • to run GP toolboxes.
  2. Connect to an APRX project, export lyrx file out of a layer.
Thank you.
Ranga_Tolapi
This question was posted more than an year ago, still I am waiting for the response from Esri or the community.
Got to know recently that, ArcGIS Maps SDK for Java also deprecated.
