Arcade expression problem
1165
03-03-2022 02:03 AM
D_CGIS
Hi, I have a problem about using Arcade .
When I run this code, I get an error message
I don't know how to fix it.
Thanks
var contents = FeatureSetByAssociation($feature, 'connected')
var updateList = []
var counter = 0
for (var content in contents) {
  updateList[counter] = {
    'globalid': content.globalid,
    'attributes': {
      'topageno': frompageno,
  counter++
return {
  'result': $feature.frompageno,
  'edit': [
      'className': 'xxxxxx',
      'updates': updateList,
Jake_S
by Esri Contributor
D,
Want to get a few bits of details. Is this being used for Utility Network?
Also, have you run this in a console or do a simple error message to get a count of the contents?
I'm wondering if the counter is not advancing.
// If there is no contents, exit the function
if (count(contents) == 0) {
    return null;
var updateList = [];
var counter = 0;
  updateList[counter++] = {'globalid': content.globalid,
    'attributes': {'topageno': frompageno}
return {
  'edit': [{
~Jake
