Arcade - Calculate Field From Intersecting Feature
1612
10-21-2019 12:35 PM
JoshSaad1
I apologize, I'm not very good with scripting/coding.  I'm trying to calculate an address point's parcel ID from an intersecting parcel using this short script:
var fsParcel = FeatureSetByName($datastore, "ParcelBoundaries", ["Parcel_Number"])
var fsParcelIntersect = Intersects(fsparcel, $feature)
var ParcelID = First(fsParcelIntersect)
return ParcelID.Parcel_Number
However, when I try to run it against 61 address points, they all come out with the same parcel ID.  I have a feeling it might have to do with the varParcelID using the First function, but I'm not sure.
Can anyone help?
Thanks.
Tags (1)
FC_Basson
You should try running the intersect on the point feature buffer geometry:
var fsParcelIntersect = Intersects(fsparcel, Buffer($feature, 1, "meter"));
