Add Image to Dashboard Details Widget
4499
01-30-2020 02:27 PM
JaredPilbeam2
I'd like to know how this dashboard displayed the green check-marks? I dug into the html and found out where it was. I then attempted a couple things to try and recreate it, but no luck. I put a url to an image I have stored on a server inside the curly brackets. And I added a fieldname of a table. It looks like they might have images in a table (costImage, scheduleImage, projectImage). Does anyone know how to do that?
<div style="font-size:.9em; font-family: Sans-Serif;font-weight:bold;">Project Health</div>
<div style="display:table;border-collapse: separate;border-spacing: 2px;">
    <div style="display:table-row-group;color:#000000;">
        <div style="display:table-row;font-size:.8em;background-color:#bbbbbb; font-family: Charcoal, Sans-Serif;color: rgba(0,0,0,.9);">
            <div style="display:table-cell;width:20%;text-align:center;vertical-align:middle;line-height:10px;padding:2px;">Cost</div>
            <div style="display:table-cell;width:20%;text-align:center;vertical-align:middle;line-height:10px;padding:2px;">Schedule</div>
            <div style="display:table-cell;width:20%;text-align:center;vertical-align:middle;line-height:10px;padding:2px;">Project</div>
        </div>
        <div style="display:table-row;font-size:.8em">
            <div style="display:table-cell;text-align:center;vertical-align:middle;line-height:10px;padding:2px;"><img height="30" src="{costImage}" width="30" /></div>
            <div style="display:table-cell;text-align:center;vertical-align:middle;line-height:10px;padding:2px;"><img height="30" src="{scheduleImage}" width="30" /></div>
            <div style="display:table-cell;text-align:center;vertical-align:middle;line-height:10px;padding:2px;"><img height="30" src="{projectImage}" width="30" /></div>
        </div>
    </div>
</div>
RickeyFight
Some of that was built in an ArcGIS online map using arcade in the popup.
Look here for the project stage part.
arcade-expressions/project-phase.md at master · Esri/arcade-expressions · GitHub
 It should give you a clue on how to add the check marks.
RickeyFight
JaredPilbeam2
Rickey,
Thanks for the reply. They are using Arcade in this pop-up (Details) widget. But, the Arcade is used in the "Project Stage" section only from what I can see. I had a look at their table inside their webmap and found they had links to each of the three images (costImage, scheduleImage, projectImage). So, I think I'll add some fields and then populate them with urls to my images.
EDIT: So, I added fields to store the url to the images. But, now I'm wondering how that field is populated for each feature, manually or automatically...?
RickeyFight
Jared Pilbeam
They have it linked to a field just like the example I believe. Do you have a link to the webapp you are looking at for reference?
JaredPilbeam2
Here's the link to the example webmap and dashboard.
RickeyFight
Jared Pilbeam
I imagine that it is updated manually. In most cases these projects don't have a lot of changes so manually updating the fields should not be too difficult.
But I am sure that you could write a python script to update the fields that runs every night.
I do believe that it could be written in arcade to display the check marks on the fly.
