Seven handy tips for getting started creating a custom dictionary style
6133
13
11-13-2024 12:13 PM
Labels (2)
megan_r
Dictionary styles provide a highly customizable way to visualize attribute-rich data in your maps and applications. With a look-up table of individual symbol parts, a dictionary script connecting attribute values to symbol keys, and a configuration file for fine tuning, these styles can be used together with the Dictionary Renderer to build complex symbols driven by multiple attributes in your data.
I created a dictionary style for the Alternative Fuel Stations layer in Living Atlas that provides information about each station at a quick glance.
In this blog, I will share some of my top tips for creating your own custom dictionary style while we take a closer look at the one I created. If you want to explore the style as you read, here are links to the style and a web map where a layer has already been configured with the style.
Tip 1 – Gather resources to use while building your style
Whenever I start building a new dictionary style, I am prepared with my favorite resources at hand. First is this blog by my colleague Thad: Create custom dictionary styles for ArcGIS. The blog shares all the tools and steps needed to build your style from start to finish. My go-to tools are:
  • DB Browser for SQLite,
  • Visual Studio Code,
  • ArcGIS Pro, and
  • A subset of the data to test the style along the way.
The Custom Dictionary Style Guide is another great place to get started with in-depth, step-by-step instructions for creating your own custom style. I also like to have the dictionary renderer toolkit handy. The toolkit is full of resources for understanding, creating, and troubleshooting dictionary styles, as well as a few sample styles worth exploring.
Tip 2 – Don't forget about built-in default symbol keys
Each individual symbol part has a unique key defined in the look-up table. The best way to create and edit these symbol parts is in ArcGIS Pro. First add the style to your project Catalog then double-click the Alternative Fuel Stations style to open the table. Here you will find all the symbol parts in the style.
Let’s focus on the Fuel Type symbols first. There are 7 fuel type symbols and one default symbol (we will get to that one in a moment), each with their own unique key. With exception of the default key, these keys follow the format “fuel-” followed by the fuel type abbreviation found in the Fuel_Type  field.
The dictionary script is an Arcade script that contains instructions on how to use attribute values to build symbol keys. The dictionary script uses $feature.Fuel_Type to produce the fuel type key. This is the first key listed, so when a feature is evaluated, the type key is the first one returned.
But what happens when Fuel_Type is empty or the full name, “Electric” is used instead of “ELEC”? In these hypothetical cases, the script would return “fuel-” and “fuel-Electric”, two keys that do not exist in the look-up table. This is where the default symbol comes in!
Dictionary renderers have built-in default symbol keys that are used when the first key returned in the script doesn’t exist in the look-up table. All you have to do is add a symbol with following key: “Invalid_P” for points, “Invalid_L” for lines, or “Invalid_A” for polygons.
Tip 3 – Vary symbol property values with primitive overrides
In this style, the outline of the symbol is used to communicate two different pieces of information about the fuel station. If the outline is a solid line, the information has been verified, but if it is a dashed line, the information has not been verified. The color of the outline stroke indicates the operating status of the station: available, plannedtemporarily unavailable, or unknown. There are 8 combinations of possible outlines:
Instead of requiring individual symbol parts for every combination, the style uses primitive overrides to drive the color of just two symbol parts: the solid verified outline and the dashed unverified outline.
A primitive override is a way to change a symbol property value, such as the outline color, differently per feature. Parts of a symbol can be tagged with a primitive name, which is used by the script to apply overrides to the parts that have been tagged with the specified name.
In the dictionary script, the status of the station specifies the color used in the override, poColor. The syntax for a primitive override is po:<primitive_name>|<property_name>|<value>. For this style this means that when drawing the verification symbol, for any part of the symbol tagged with status-color, the Color is replaced with the value of poColor
Now to tag the symbol parts with the primitive name. This override will be applied to stroke of the verified and unverified symbols in the look-up table. From the look-up table, select the Verified symbol and navigate to the Layer Properties tab. From here use the element drop down to drill down to the Shape Fill symbol, then format that symbol to get down to the fill and stroke properties. In the structure tab, click the little tag symbol next to the stroke and specify status-color as the primitive name. Now repeat for the unverified symbol.
With the symbol elements tagged, the style now supports all 8 possible outline combinations of verification statuses and operating statuses using just two individual symbol parts.
Tip 4Take advantage of configuration properties
Now if you are familiar with the Alternative Fuel Stations Living Atlas layer you may be thinking, “wait a minute- there is no ‘verified’ field in that data!” You caught me. I am using a subset that I modified, adding the ‘verified’ field which will come in handy for a future blog. This style works with the verified field, but maybe you are using the Living Atlas layer and don’t have that field in your data. That's why I created a configuration property that allows you to include or ignore the verification field.
The configuration file is a JSON object where you can define additional configuration options that alter how symbols draw. This style has multiple configuration options, but we’ll start with the use_Verified_Field configuration. Here I specified the name of the configuration, the default value, possible values, and a brief description. I also included the Verified field as a symbol field leveraged by the dictionary script. You can really see this come to life in ArcGIS Pro:
When the use_Verified_Field configuration is on, the dictionary script will use the value in the verified field to return a key for a solid or dashed line. When it is off, the dictionary script will return a key for the solid line for all features. To leverage the value of a configuration property in the dictionary script, use the syntax $config.name or in this case, $config.use_Verified_Field:
Now anyone using this style to symbolize a layer can control if the verified field is used.
Tip 5Know when to use a symbol field or text field for labels
That last configuration property was about how symbol parts are calculated using a symbology field in the data, but now let’s look at a property to turn labels on and off. In the layer, EV charging stations include information about the network they belong to in the EV_Network field. If a station doesn’t belong to a network, that field is populated with “Non-networked.”
First, add a new symbol for the label to the look-up table then make sure it is a shape text symbol in the layer properties tab. To use the EV network in the data, replace the text string with the field name in brackets, in this case, [EV_Network]:
In the configuration file, I created the show_EV_Network property so that you can turn the labels on and off. I also specified the EV_Network field as a symbol field. Why not a text field you askText fields work great when you want to label all features. If I had chosen to use a text field, every feature would be labeled with their EV_Network value and EV stations that aren’t networked would have a “Non-networked” label. I decided I only wanted networked EV stations to be labeled, so made that a condition in the dictionary script
Text fields cannot be accessed by the dictionary script, which means that they can’t be used as variables in the logic. Since the script needs to use the EV_Network value to determine whether to return the label key, I included the EV_Network field as a symbol field in configuration file.
Tip 6 – Use unique primitive names
The final configuration property in this style is the show_Connector_Type property which allows you to show or hide a banner that displays all the available connector types at an EV charging station. The available connectors are listed in a single field in the Alternative Fuel Stations layer. While the configuration is a simple on/off property like the others, this portion of the dictionary script is a bit more complicated as we have to consider which connector symbols are used, how those symbols are positioned, and how wide the banner needs to be to accommodate that many symbols:
Let’s begin with the banner width. The look-up table contains symbol parts for banners that will fit 1, 2, 3, or 4 connector symbols. In the dictionary script, we create an array of the available connector types and count the number of objects in the array to determine which banner to use.
Then the connector symbol keys are returned. The script uses a for loop to iterate through each object in the array, returning the key for each corresponding connector type symbol part. If we stopped here, all the connector symbols would draw on top of each other. Luckily, we can use primitive overrides here!
The X offset override shifts tagged symbol parts along the x axis.  With each iteration of the for loop, 11 points are added to the X offset, so that the following symbol will be 11 points to the right of the previous symbol. In the look-up table, each connector symbol has been tagged with a primitive name that follows the syntax [connector type]_marker (e.g. J1772_marker, CHAdeMO_marker, etc.).
So if a station has two connectors, J1772 and CHAdeMO, the keys would look like this:
  • Banner key: background-2
  • Connector type keys: con-J1772;po:J1772_marker|OffsetX|17;` and `con-CHAdeMO;po:CHAdeMO_marker|OffsetX|28;
Unlike our previous example with primitive overrides, each symbol part needs to have a unique primitive name because the offset values to be applied to each symbol so that they do not overlap.
Tip 7 – Return keys in drawing order
In the last line of this dictionary script, we return the string of keys, which tells the client what individual symbol parts to use to create the final symbol. The order the keys appear in the string dictates the order in which symbol parts are drawn. When you look at a final symbol drawn with this style, you can see that the connector types draw on top of the banner, and the banner draws under the fuel type symbol and the outline, while accessibility indicator draws on top:
In this dictionary when all the configuration properties are on, the keys are returned in the following order: fuel type, network name, EV banner, EV connector types, verified key, fuel type, and access.  The fuel type key is returned twice because the built-in default key (Invalid_P) is used only when the first key returned produces a key not in the look-up table. Adding the fuel type key a second time ensures proper drawing order, but another option is adjusting the symbol parts to remove unnecessary fill symbols that may “bury” symbols.
And that’s it- you now have all my top tips for creating your own custom dictionary style! You can dig into this style further by downloading it here or get started building your own custom style. Let me know in the comments below what ideas you have for creating custom dictionary styles!
13 Comments
AndresCastillo
Hi @megan_r ,
This blog post is excellent.
Thank you for sharing it.
It clearly explains the full workflow to define a custom web symbol.
Question:
Once the style was shared as a web style, how were you able to apply the web style url to the web map operational layer?
I took a look at your web map using ArcGIS Assistant, and the layer renderer shows the url to the web style with item id a99d8d715e1e47bea8b5dda31d70caad.
 ‎Also, out of curiosity, the blog did not cover the scalingExpressionInfo key of the renderer.
Here is the renderer JSON:
                    "renderer": {
                        "type": "dictionary",
                        "url": "https://www.arcgis.com/sharing/rest/content/items/a99d8d715e1e47bea8b5dda31d70caad",
                        "fieldMap": {
                            "Fuel_Type": "Fuel_Type",
                            "Current_Status": "Current_Status",
                            "Accessability": "Accessability",
                            "EV_Connector_Types": "EV_Connector_Types",
                            "Verified": "Verified",
                            "EV_Network": "EV_Network"
                        "configuration": {
                            "show_EV_Network": "ON",
                            "show_Connector_Type": "ON",
                            "use_Verified_Field": "ON"
                        "scalingExpressionInfo": {
                            "expression": "2",
                            "title": ""
I am on ArcGIS Enterprise 11.2 (using the newer map viewer), and ArcGIS Pro 3.2.2
I analyzed the Pro Dictionary style with no errors, nor warnings, then published it as a web style.
I shared the web style to the designated and configured portal groups as per this article:
https://support.esri.com/en-us/knowledge-base/problem-the-custom-web-style-is-not-displayed-in-arcgi....
But, I do not see the dictionary web style available for me to apply to the web map operational layer.
I'd like to symbolize at the web map level, not so much from ArcGIS Pro layer level.
@RussRoberts
AndresCastillo
I saw the reply by @RhettZufelt in this article, which is great for overwriting a web style with new symbols.
https://community.esri.com/t5/arcgis-online-questions/web-stylx-in-map-viewer/m-p/1474193#M59237
But my issue is that the dictionary web style is not available to choose in map viewer style options.
Note that my web style contains 46 point symbols.
Here are the typeKeywords from the web style item data json,
which match the typeKeywords from the a99d8d715e1e47bea8b5dda31d70caad item that @megan_r  uses in her web map:
    "typeKeywords": [
        "ArcGIS Pro",
        "Dictionary",
        "Platform",
        "pointSymbol",
        "Style",
        "Symbology",
        "Symbols",
        "Web Style"
I looked into the typeKeywords due to @RussRoberts reply on this thread, even though the reply is within the context of a new style workflow only in AGO:
https://community.esri.com/t5/arcgis-online-questions/help-needed-custom-web-styles-not-showing-unde...
RussRoberts
Esri Notable Contributor
Hey @AndresCastillo we currently do not support using dictionary web styles in Map Viewers symbol styler experience. We read them into the web map but don't have the experience yet for using them for additional configuration. Thank you for your feedback!
AndresCastillo
Thank you for your reply @RussRoberts !
Seems then that if I want to apply the dictionary web style to a feature layer in a web map, I will need to do so by adding the renderer to the item data json.
Another note,
when I apply the Pro Desktop Style to the database layer in pro (in other words, not the web feature layer), then publish the web layer as a map image layer (MIL) and feature layer (FL) in the portal, only the MIL retains the dictionary symbology. The feature layer just keeps a basic point symbol.
Interesting though, that both the corresponding map service and feature service rest end point pages BOTH show a basic point symbol for the renderer.
megan_r
I'm glad you enjoyed the blog, @AndresCastillo!
As Russ mentioned, you can't currently configure a layer with a dictionary style from Web Map Viewer. Please consider submitting an Idea for this capability.
Now for this blog, I used ArcGIS Pro to symbolize the Alternative Fuel Stations feature service with the dictionary web style, then shared the map as a Web Map. When configuring the symbology, I set a scale factor of 2 because I wanted all the symbols to be larger for demonstration purposes, but you can also write an Arcade expression. Here's some documentation on that: ArcGIS Pro - Scale dictionary symbols
AndresCastillo
very nice @megan_r , thank you
TheRrrr42
@megan_r
Thanks for the writeup and examples. I attended your DevSummit presentation and am trying to implement these with some water utility valve data. I'm looking around in the military styles and the provided style but am having trouble determining if I can use multiple primitive overrides on a single key. Is this possible? For example trying to change the fill color on a marker symbol and the size of that symbol. Do you have any snippets that show the formatting of this?
Thanks!
megan_r
Great question @TheRrrr42 - you can apply multiple overrides to the same symbol!
Here is an example where I vary the color and rotation of the same 'plane' symbol with two different overrides. The script looks like this:
// Arrival airport key
var plane_color = ''
if ($feature.arrival_airport_iata == 'SAN') { plane_color = '#704489' } // purple
else if ($feature.arrival_airport_iata == 'LAX') { plane_color = '#004DA8' } // blue
else if ($feature.arrival_airport_iata == 'SNA') { plane_color = '#A80084' } // magenta
else { plane_color = '#686868' } // gray
keys = keys + 'plane'
  keys += ';po:plane_direction|Rotation|' + $feature.heading // rotate plane symbol by heading
  keys += ';po:color|Color|' + plane_color + ';' // specify color of plane symbol
When tagging the symbol with the overrides in ArcGIS Pro, the tags actually belong on different "levels" of the symbol. The plane_direction tag is applied on the shape symbol:
And the color override goes a few levels deeper on the embedded polygon symbol: color_override.jpg
You would apply the size override on the same level as I applied the rotation override in this example. Hope this helps!
AaronBarkan
@megan_r
Thank you for posting this - really helpful stuff!
I'm having trouble adjusting the size of the symbol through the dictionary script. I want to implement three different size options for my symbology. Following your example with color, I set a primitive name of 'resizable' and added this code to my dictionary script:
var size = "10"; // Default size - 10pt
if ($feature.size == "small") { size = "10"; } // 10pt
else if ($feature.size == "medium") { size = "15"; } // 15pt
else if ($feature.size == "large") { size = "20"; } // 20pt
keys += ";po:resizable|Size|" + size + ";";
However, the symbols still appear to be the same size. I suspect I didn't set the correct primitive name. Do you have an example of how to set the size using a dictionary script?
Thank you!
AndresCastillo
@megan_r
How can I add the predefined symbol parts for diferently sized banners for the lookup table?
I tried in layout mode, specifying the width and height, but if you change the width, the height also changes:
Element properties:
The styles pane does not give us access to the width of the symbol:
AndresCastillo
@megan_r
My teammate and I saw that the predefined box sizes can be edited in the items table of the stylx in dbbrowser for SQLite.
Specifically, we must edit the x or y axis for the rings in the markerGraphics key.
  "type": "CIMPointSymbol",
  "symbolLayers": [
      "type": "CIMVectorMarker",
      "enable": true,
      "anchorPointUnits": "Relative",
      "dominantSizeAxis3D": "Y",
      "size": 50,
      "billboardMode3D": "FaceNearPlane",
      "frame": {
        "xmin": 0,
        "ymin": 0,
        "xmax": 100,
        "ymax": 100
      "markerGraphics": [
          "type": "CIMMarkerGraphic",
          "geometry": {
            "rings": [
                [80, 60.2],
                [79.6, 62],
                [78.6, 63.6],
                [77, 64.6],
                [75.2, 65],
                [14.8, 65],
                [13, 64.6],
                [11.4, 63.6],
                [10.4, 62],
                [10, 60.2],
                [10, 39.8],
                [10.4, 38],
                [11.4, 36.4],
                [13, 35.4],
                [14.8, 35],
                [75.2, 35],
                [77, 35.4],
                [78.6, 36.4],
                [79.6, 38],
                [80, 39.8],
                [80, 60.2]
          "symbol": {
            "type": "CIMPolygonSymbol",
            "symbolLayers": [
                "type": "CIMSolidFill",
                "enable": true,
                "primitiveName": "cbstatus",
                "color": [0, 0, 0, 255]
                "type": "CIMSolidStroke",
                "enable": true,
                "capStyle": "Round",
                "joinStyle": "Round",
                "lineStyle3D": "Strip",
                "miterLimit": 4,
                "width": 4,
                "height3D": 1,
                "anchor3D": "Center",
            "angleAlignment": "Map"
      "scaleSymbolsProportionally": true,
      "respectFrame": true,
      "clippingPath": {
        "type": "CIMClippingPath",
        "clippingType": "Intersect",
        "path": {
          "rings": [
              [0, 0],
              [100, 0],
              [100, 100],
              [0, 100],
              [0, 0]
  "haloSize": 1,
  "scaleX": 1,
  "angleAlignment": "Display"
Here is what the rings look like plotted out on a graph:
To modify the width, modify the x coordinates respectively.
AndresCastillo
FYI, DB Browser for sqlite sometimes seems to have an incorrect view of the actual json for an item in the items table:
In that case, it is better to verify the content column of the items table using python's sqlite3 library:
import sqlite3
# Path to your .stylx file
stylx_path = r"D:\ArcGIS_Projects\<name>.stylx"
newlines = "\n" * 5
# Connect to the SQLite database
conn = sqlite3.connect(stylx_path)
cursor = conn.cursor()
# Query the ITEMS table for NAME and CONTENT columns
cursor.execute("SELECT KEY, CONTENT FROM ITEMS")
rows = cursor.fetchall()
# Define the names you want to match
keys_to_match = {"CB2", "CB3"}  # Use a set for fast lookup
# Print each row with clear formatting
for key, content in rows:
    if key in keys_to_match:
        print(f"Key: {key}\nContent: {content}\n{'-'*40}{newlines}")
conn.close()
AndresCastillo
Once the mobile style has been published as a web style, you can also see the content json in arcgis assistant for the item's resources
Contributors
Labels
