Hi Rachel
Hummm I uploaded the screen shots in the original request. I am pretty sure now it is a shape file issue - I exported the file to a gdb and the Field calculator reworked it fine. . Just wondered why -Students were asking and I was clueless.
It is good to show them that confirming calculations is important.
Lynn
Lynn Songer, Ph.D.
Geography and GIS Instructor
Social Science Department
Lane Community College
4000 East 30th Ave
Eugene, Oregon 97405
Office Phone: (541) 463-5493
Fax: (541) 463-4160
>>> Rachel Guttmacher <geonet@esri.com> 11/15/18 3:04 PM >>>
GeoNet Re: Why can't I add two long fields into a float? reply from Rachel Guttmacher in Managing Data - View the full discussion
Hello Lynn,
Could you provide a few numerical examples to your results? What are the values in fields A, B, C, and D?
Do you see this in all datasets?
What software are you using?
If you try a new ArcMap map document or ArcGIS Pro project (assuming you're using these), do you see different behavior?
Thank you!
-- Rachel
Esri Support Services
Reply to this message by replying to this email, or go to the message on GeoNet Start a new discussion in Managing Data by email or at GeoNet Following Re: Why can't I add two long fields into a float? in these streams: Inbox This email was sent by GeoNet because you are a registered user.
You may unsubscribe instantly from GeoNet, or adjust email frequency in your email preferences
