Why can't I add two long fields into a float?
4955
7
11-15-2018 12:17 PM
LynnSonger
I have  two long integer fields in a shapefile  A and B.  I created a new long integer field C and a float field D.  When I add A and B using the field calculator into Field C and Field D my results are not always the same.
I performed the addition of A and B into a field set to Double field and the results were correct.  Just wondering why?
rachelg_esri
Hello Lynn,
Thanks for that clarification - I missed the screenshot!
I was able to reproduce the issue in ArcMap 10.6.1 on my end, but after a bit of digging, I realized this is expected behavior. Here's why: Float fields can only store a precision of up to 6 values. If the numbers you are adding up (or the output of the addition) is longer than 6 values, the number will be rounded. For example, if I try to enter the following number: 123456789 into a float field and then save my edits, the number becomes 123457000. This is the way Float fields work in many different softwares and is simply the nature of the field type.
When you bring your data into a geodatabase, geodatabases ignore precision and scale values that other data types have limits for, so you may see a difference in behavior between, for example, shapefiles and file geodatabases.
In general, unless you're trying to save storage space, I would recommend you use Double fields, as they allow the most precision and you can store the widest range of numbers.
For more information, see: ArcGIS field data types—ArcGIS Help | ArcGIS Desktop
Best regards,
Rachel
Esri Support Services
Rachel Guttmacher
ArcGIS Online Technology Lead
LynnSonger
So I exported the file into a gdb and recalculated the float field - It would correctly. So it seems to be a shapefile problem.
AdrianWelsh
MVP Honored Contributor
Lynn,
Can you show what field calculations you are using (and what language)?
LynnSonger
Hi Adrian
So I was just using the Field Calculator - set to VB Number calculation
Its odd.
Lynn
Lynn Songer, Ph.D.
Geography and GIS Instructor
Social Science Department
Lane Community College
4000 East 30th Ave
Eugene, Oregon 97405
Office Phone: (541) 463-5493
Fax: (541) 463-4160
>>> Adrian Welsh <[email protected]> 11/15/18 12:23 PM >>>
GeoNet Re: Why can't I add two long fields into a float? reply from Adrian Welsh in Managing Data - View the full discussion
Lynn,
Reply to this message by replying to this email, or go to the message on GeoNet Start a new discussion in Managing Data by email or at GeoNet Following Re: Why can't I add two long fields into a float? in these streams: Inbox This email was sent by GeoNet because you are a registered user.
You may unsubscribe instantly from GeoNet, or adjust email frequency in your email preferences
DanPatterson_Retired
Double or long.
Did you try just deleting the field, adding a new one (Double or Long) and trying the calculation?
Also, switch to the python parser to prepare yourself now for the future
rachelg_esri
Hello Lynn,
Could you provide a few numerical examples to your results? What are the values in fields A, B, C, and D?
Do you see this in all datasets?
What software are you using?
If you try a new ArcMap map document or ArcGIS Pro project (assuming you're using these), do you see different behavior?
Thank you!
-- Rachel
Rachel Guttmacher
LynnSonger
Hi Rachel
Hummm I uploaded the screen shots in the original request. I am pretty sure now it is a shape file issue - I exported the file to a gdb and the Field calculator reworked it fine. . Just wondered why -Students were asking and I was clueless.
It is good to show them that confirming calculations is important.
Lynn
Lynn Songer, Ph.D.
4000 East 30th Ave
Fax: (541) 463-4160
>>> Rachel Guttmacher <[email protected]> 11/15/18 3:04 PM >>>
GeoNet Re: Why can't I add two long fields into a float? reply from Rachel Guttmacher in Managing Data - View the full discussion
Hello Lynn,
Thank you!
-- Rachel
rachelg_esri
Hello Lynn,
Best regards,
Rachel
Rachel Guttmacher
