What causes a feature class to become unversioned
1261
04-09-2014 08:22 AM
JoshWhite
Honored Contributor
What causes a feature dataset to suddenly become unversioned?  I was editing a versioned feature class adding attachments.  I needed to make an edit to an individual feature and I kept getting an error message that said I couldnt change a table without being in an edit session.  Turns out that the dataset lost its versioning and I had to reregister as versioned.  Is there something causing this to happen?  I also discovered that multiple other datasets in the same SDE geodatabase also had to be registered as versioned again.  I also ran MXD Doctor just to see if the MXD was causing an issue.  As of now, everything appears to be working again but I want to know why this happened in the first place.
Josh White, AICP
Principal Planner
City of Arkansas City
AsrujitSengupta
Was any new data added to that Feature Dataset?
A feature dataset itself is not versioned or unversioned -- the feature classes inside of the feature dataset are the ones that get versioned and unversioned. So if there is any new data added to a Feature Dataset or if there is any Feature Class within the dataset which is not versioned, then the Feature Dataset will also show up as not versioned.
JoshWhite
Honored Contributor
But why am I allowed to add attachments but not edit the feature class?    I guess that's because the table is on its own with a relationship class.  The whole hierarchy thing is just confusing.  If I have to register the feature classes at the feature dataset level how can you say that the dataset is not versioned?    I don't recall making any changes that would have caused this but it is hard to say when it happened.  This is something I find extremely frustrating about SDE.  In order to add anything new I have to stop my services, I also have to stop my services to remove the locks to register anything as versioned.  I didn't have to deal with that when I was using file geodatabases for my services.  It may be important to note that the main reason I switched to SDE was for feature services and the attachments feature.  I am currently the only user so I don't have to worry about multiple editors.  The reason I have everything versioned is for editing purposes only and of course if in the future I add users, I would already have things set up that way.
Josh White, AICP
Principal Planner
