Versioning: Create new Version throws Error: (Parent) Version not found
1304
02-18-2011 01:37 AM
JanKorte
I have a Problem creating a new Version using Toolbox 'Create new Version' when I use a subordinated Version of DEFAULT wich is created by User 'SDE' via ArcCatalog.
To reproduce I will show you what I did before:
1. A Database has been created by the SDE Administrator
1. I've opened an existing Database called SDE.DEFAULT in ArcCatalog using my Database Useraccount
2. I rightclicked to create a new Version of Default and named it 'test'
3. This worked for me, my Version is shown under 'Versions':
[INDENT]
test|MyUsername|Public|lastChangeDate
[/INDENT]4. I opened ArcMap and the Projectfile pointing to the Database
5. I opened Version 'MyUsername.test'
6. Changed something and SAVED
7. After this I used the Toolbox using "Create new Version" and typed in a new Versionname 'edit'
  • Parent-Version: "MyUsername".test
  • Name: test
  • Description: none
  • Role: Private
8. Clicked OK
After I've clicked OK, ArcMap throws the error 'Can't create Version. Version not found ["MyUsername".test]'.
What is wrong? Maybe some Database Security is not set? I can't imagine that it's a bug.
Scenario uses following Products:
- ArcMap 10
- ArcSDE
- Oracle 11 Server
Thanks for all advice!
Jastro
JanKorte
no Support? - Problem is still up to date!!
Thanks
JanKorte
Solved: Problem does not exist anymore. Database Error made it happen. Thread can be closed.
