???Version view??? for tables\layers,
39819
32
04-08-2014 02:49 AM
by Anonymous User
Not applicable
Original User: [email protected]
I couldn???t figure out how particular tables\layers are given the ???Version view??? property while others don???t have it
For example, in the screenshot below, the ???project??? table has this property
[ATTACH=CONFIG]32904[/ATTACH], [ATTACH=CONFIG]32905[/ATTACH]
In return, the ???companies??? table doesn???t have it.
[ATTACH=CONFIG]32906[/ATTACH], [ATTACH=CONFIG]32907[/ATTACH]
Form where this property (versions view) is set?
Thank you
Best
Jamal
ColinZwicker
Jamal,
Upon further review I think my original idea (DBO user related) was incorrect.
For the dataset that is failing, does it contain any user defined fields?
Can you try adding a field to the table before you register it as versioned?
E.g., the field set would contain ObjectID and myTextField
The view is correctly created for me when using a DBO mapped user if the table has more fields that just the default ObjectID field (a questionably useful table schema).
Colin
by Anonymous User
Not applicable
Original User: asrujit
Colin,
Yes, that seems to have done the trick!
JamalNUMAN
Legendary Contributor
Jamal,
Colin
Many thanks guys for the help.
Colin�?�it worked as a charm.
Adding fields (other than the defaults) to tables before applying the �??register as version�?� solves the issue.
Interestingly, if a table is �??registered as version�?� before adding fields then the version view is not created. In this case, unregistering this table and re-registering it will create the version view provided that other fields are created before applying the registration.
Very much appreciated
Jamal
Jamal Numan
