Extrapolating info from a shapefile
1312
04-10-2014 01:06 PM
MarikaDobos
I have a polygon file and a point shapefile.  What I would like to do is merge or join the two so that every point can be associated with attributes from the polygon shapefile.  What is the best way to tackle this?  Right now I don't have anything in the tables that can link the two shapefiles.  I just need to extrapolate the information where the the two shapefiles overlap.  Suggestions?
Thanks!
Marika
TimWitt
Marika,
Did you try and use the Spatial Join tool? I think that should be able to do what you need.
Hope this helps!
Tim
