Values removed from domain remain in attribute table for historical records?
2351
12-11-2023 12:36 PM
Boomer1187
Hello!
I have a feature class in an enterprise geodatabase that contains domains with different contractor names. I was wondering, if several of these contractors will retire and I delete them from the domain drop down, will their names show up in the attribute table for historical inspections that they completed? Or does every record/instance that the retired contractor's name shows up dissappear from the feature class/attribute table as well? I want to ensure that all of the retired contractors names will still display when they are removed from the domain.
Thanks!
RyanUthoff
MVP Regular Contributor
Removing values from a domain won't modify your data. However, there are two things to consider.
1. You won't be able re-select them again if you ever needed to use their name (at least not with doing a field calculate within Pro).
2. If your Code is different from the Description in your domain (ex: a code of 5 = John Smith), then it will only display the code once you remove the domain (ex: it will only show the code of 5 as the value instead of the person's name).
Otherwise, it's safe to remove domains. It won't modify the data itself.
RyanUthoff
Bud
Legendary Contributor
If wanted, could the user type in the old value as a field calculation/constant, as a workaround if the value is no longer available from the field calculator via clicking from a list?
RyanUthoff
Yeah, that's what I meant when I said when doing a field calculate.
Boomer1187
@RyanUthoff Thanks so much for your response - that is good to know! I will keep #2 in mind to ensure that the data isn't modified
