XML Import Failing : 160320: The subtype code does not exist.
2238
12-11-2023 10:28 AM
Labels (3)
JacquelineAlessi
Hi I am trying to import a FGDB Schema from XML, the XML export of the schema worked fine. However upon import I get the following error: 160320: The subtype code does not exist (Name)
There is no subtype by the Name listed in the error in the FGDB, there is a FC by that name. How do I determine the root cause and resolve it? There are no resources available online for this error code.
MarceloMarques
You can try to import one featureclass at a time till you discover which featureclass is causing the issue, then you can dig more into the domains of that featureclass to find out what the problem might be.
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
JacquelineAlessi
Thanks Marcelo, we are in the process of doing that now, but we have 15k classes in this DB. OOF.
MarceloMarques
You could try to write a SQL query to access the geodatabase domains information of your ArcSDE Geodatabase to try to identify the featureclass(es) and domain(s) causing the issue.
Example: Resolving domain codes to description values using SQL—ArcMap | Documentation (arcgis.com)
Example: Discovering domain usage using SQL—ArcMap | Documentation (arcgis.com)
