UK counties & Germany Two digit zip code for Esri map (Power BI)
1128
10-09-2018 07:32 AM
dklee
Hello! All,
i am trying to build the market intelligence report (UK & Germany) by using Esri map (In power BI). My data format for each county is 1. UK (County based) 2. Germany (First two digit based zip code). When i try to build it many of areas are missing.(Even if the local name is correct) Can i provide you with my list of counties/Zipcode for you to assist with making my map?
