Topology Errors
3084
9
04-17-2014 04:32 AM
CrystalCowardin
I have our parcels in a topology.  When I validate the topology, errors are returned that show the outside boundary of the polygons where the roads would fall.  I mark all the errors as exceptions.  The next time I validate topolgy, the same errors are appearing even though I've marked them as exceptions.  I've gone through the process at least 5 times and they are still coming back as errors.  Why aren't they staying as exceptions?
MarkBoucher
Honored Contributor
Based on my limited experience, with topology, if you recheck the topology after marking something as an exception, it will pop back up again as an error. I think this is because the topology exceptions are not stored in the topology. That would be really cool.
I imagine it would be tough to store the exception and then keep track of which features are related to the them so that the error exception would be removed if any of the related features were modified.
CrystalCowardin
I have over 3,500 exceptions marked and they do not show back up in the error inspector  unless I check the box show exceptions.  I have about 70 that I've marked as exceptions but are still coming back as errors.  I'm concerned with those 70.
MarkBoucher
Honored Contributor
Maybe you need to check if the topology error tolerance. If you raise that, would the error go away and the accuracy still be acceptable?
CrystalCowardin
The tolerance is set to the default.  Not sure how these are different than the other 3500.  I'm stumped.
CrystalCowardin
I'm still experiencing this.  I validate the topology every day and am still receiving the same 70+errors that I've previously marked as exceptions.  Has anyone else been experiencing this?
MarkBoucher
Honored Contributor
I don't think Arc Map remembers the exceptions.  It has been a while, but my recollection is if you validate again, the previous exceptions are lost and you have to redo the exceptions. A little frustrating.
CrystalCowardin
ArcMap does remember the exceptions and stores them.  I'm able to see the 3000+ exceptions I've previously marked in the past 3 years.
MarkBoucher
Honored Contributor
Nice to know that it does remember. I'll have to confirm that for myself next time I have to use it. I just recall wanting that functionality for the topology tools and not seeming to be able to get it; that is, it seemed like whenever I re-validated that it would re-highlight those that I had marked as exceptions.
TiffanyPuett
The exceptions should only be lost if you edit the geometry of the feature that is excepted and then validate. Make sure you have dirty areas turned on and see if anything goes "dirty" during your edits. That could tell you more about what is happening. Esri should have dirty areas on by default.
