Synchronize replica failed Operation is invalid for this stream[table_name]
1161
03-25-2011 07:41 AM
AgostinoCirasa
I have a two way replica between ArcSDE 9.3.1 on Oracle 10gR2 and ArcSDE Personal on Sql Server Express 2005.
I want to Synchronize a table with Raster Column.
When I Synchronize changes from Sql Express to Oracle i get this error:
"Synchronize replica failed Operation is invalid for this stream[table_name]"
If i don't load images the Synchronize takes place, loading an image in raster column i receive the message above.
Someone can help me?
Agostino.
by Anonymous User
Not applicable
Did you find a resolution to this? I am having a similar error message as i replicate in SQL 2008 R2. I added Raster as a field type to this data set and did not see any problems. However when the user does a bulk edit field calculate I get the error message.
EzequiasRodrigues_da_Rocha
I got the same issue between Oracle 11g and SqlServerExpress 2012 two_way syncronization.
Does anyone have any sugestion?
Is that a restriction?
Regards
Ezequias Rocha
