Select by Location in ArcMap 10.2.1 issues different SQL than in ArcMap 10.0?
2234
07-21-2014 03:18 PM
MikeDunham-Wilkie
I have a large point layer and I'm doing a "Select by Location" to select all points that intersect a specific selected polygon from a polygon table.
In ArcMap 10.0 the SQL that was executed was basically the following:
1. Stick the se_rowid of the polygon into the sde_logfile_data table
2. Select all points that intersect the polygon
In ArcMap 10.2 the SQL is an alternating sequence of:
1. Insert the rowids of 10000 points into the sde_logfile_data table
2. Select count(distinct sde_row_id) from sde_log_table where logfile_data_id = ...
i.e., sde_logfile_data keeps getting inserted into and the subsequent selects take longer and longer.  ArcMap ends up stalling and I have to kill it.
Does this sound familiar to anyone?
Many thanks
Mike
