Route Editing - NaN Measure value problem
2730
06-05-2014 11:22 AM
ShaningYu
Honored Contributor
I have a Linear Reference FC class.  One of the features is identified without Measure value (NaN) using the Identify Route Location Tool.   How can the problem be fixed?  Thanks.
ShaningYu
Honored Contributor
Fixed using the procedure below:
1)  After selecting a line feature for editing, click the Sketch Properties icon to pop out the list of point interstices.
2)  Find the points with NaN values and then delete them.
3)  Click Add Vertex tool icon and then add new vertices, also check if M value is not NaN.
4)  Save the Edits.
ShaningYu
Honored Contributor
4)  Save the Edits.
TedKowal
Honored Contributor
When I am creating/editing routes for my roads another trick I use is simply to calculate NaN values based upon the begin/ending values.... or calibration points.
alex_friant
What do you mean by that? What exactly is your technique to fill in the in between "NaN" values? When I put a beginning value and end value and finish sketch, the "NaN" values for the middle vertices stays "NaN". Do you have a trick to "fill in" those values with the correct geometrically derived lengths?
I can use calibration points, but those don't work on complex lines ("Y" shaped lines for example). Any help would be appreciated.
TedKowal
Honored Contributor
What you are describing are multi-part lines.  You will have to decide when creating an LRS how to handle both directions there are a few options available (I believe you want to preserve overlapping segments).
Creating a complex (looping) route—Help | ArcGIS Desktop
Complex routes
The process of creating a complex route is very similar to that of creating a simple route. The only real difference is that you must build a complex route in pieces. Once the pieces are created, they can be merged.
Take note that in creating a complex (looping) route in the task, care has been taken to set the measures appropriately for each of the two halves of the route that are eventually merged. If this is not possible in your situation, you can still merge the pieces. Then at a later time, the measure values can be reset.
Personally I avoid complex dynamic segmentation, I have ALWAYS found a way to create a simple route even under complex situations (Sometimes you got to think out of the box!)
