Offsetting a line (like in CAD)
2320
8
01-17-2014 11:02 AM
MikeHenson
I have to draw a few parallel lines in my map. In cad, I would normally just offset the line to get a new parallel one. Can someone tell me how I might do this in arcmap? Thanks
MikeHenson
DUH....
found it, thanks everyone.  I was looking in the toolbar, not the "drop down" part of the editor toolbar. It works great. I appreciate the comments.
MarkBoucher
Honored Contributor
MikeHenson
I am not finding that extension. I am using the standard license. Could it be possible that I dont' have that with my license? Thanks
michaelcollins1
It's in the editor. Click on the Editor tab.
MikeHenson
nope...still don't see it.
KarinPierce
The copy parallel tool is on the COGO toolbar.
michaelcollins1
I can't remember if it's there by default or I added it.
If you need to add it to the editor tab:
go to Customize\Customize Mode
Commands tab
type in "copy parallel"
drag the command to the editor tool bar
MikeHenson
DUH....
JoshuaDamron
As Mark mentioned earlier you can also a place the Copy Parallel tool (or pretty much any tool) on a toolbar via Customize>Customize Mode  (see attached image)
