ODBC error
5058
01-12-2015 06:14 AM
SaraLazzaroni
Dear Members,
I am trying to load a .dbf file (created with ArcGIS) into Stata using the "odbc load" command. However, Stata keeps reporting the following message:
"The specified DSN contains an architecture mismatch between the Driver and Application"
I created my DSNs twice for both 64 and 32 bit applications but Stata cannot read the ArcGIS .dbf file in any case.
Is anyone able to help?
Kind regards,
Sara Lazzaroni
MikeCusi
Hi Sara,
I assume you are using 64 bit Stata. If all you want is to load the data, I would use csv instead of dbf when loading data in 64 bit Stata.
Cheers,
Mike
