Object ID recalculate
6927
04-18-2021 11:11 AM
A_n_d_r_e_a
Dear Community,
is there a possiblity to recalculate the Object ID field? I just add some Rasters to a mosaic Dataset.
As you can see after the synchronization of the mosaic dataset the first count starts at 4345 which at want to have of course at 1.
Can I recalculate the Object ID somehow?
Thanks forward!
Greetings,
Andrea
DanPatterson
No you can't, you will have to create a new field (eg OBJECTID2 ) and use the "autoincrement" field calculator expression
Calculate Field Python examples—ArcGIS Pro | Documentation
... sort of retired...
DanPatterson
A_n_d_r_e_a
Ok, Thanks 😉
